How to identify a numeric string?
I need to identify a numeric string. The number can even be in the exponential format. How can I do this?
-Vasanth.
Ya Ya
(3,572 Views)
Hi Vasanth,
by 'identify' you surely mean 'convert from string to number'...
So have you tried 'Scan from string'? You can use '%f' (or %g or %e) as format code to convert any floating point number.
(3,564 Views)
Hi
Have a look at the Scan From String vi. This vi allows you to scan a string for different data. If you wire a numeric constant as default, you get "normal" numbers, but also numbers in the "xEyy" form.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,564 Views)
Hi Gerd and Becktho,
                Thanks for your suggestions. I will look into it.
Vasanth.
Ya Ya
(3,558 Views)
