Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to identify the code used by a code interface node
Rexamillion Zed
Member
06-17-2003
12:45 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have an old Macintosh system running Labview 3.1.1 that contains CINs. How do I view the code used by these CINs or identify the .lsb files?
0
Kudos
Message
1
of 2
(2,823 Views)
Reply
Re: How to identify the code used by a code interface node
Dennis_Knutson
Knight of NI
06-18-2003
08:34 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I don't think that there's a way to do either. Even if you knew the name of the .lsb, the .lsb file does not have to be present after it's been loaded into the VI and you would still need the original C program to see the code.
1
Kudo
Message
2
of 2
(2,823 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
