How to implement Com-Objects?
I use an ActiveX software which should be implemented in LabView. Now I want to know, if it is possible to implement Com-Objects from this ActiveX software in my LabView Application. When it is possible, where can I find this Com-Objects? Of course the ActiveX components are already implemented in LabView.
(3,563 Views)
hello mobmon,
create an "Automation refnum" - control on your frontpanel (can be found under the "Refnum" palette), then select your object or browse for it (right klick "Select ActiveX class"). after that you have to wire the control with the "Automation open" and "Close Reference" functions from the "ActiveX" palette. After that you have access to methods an properties.
hope it works
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,563 Views)
I tried to do this, but in my Refnum palette I only have Application RefNum, ActiveX RefNum and some other RefNums. Automation Refnum is not available. Is the ActiveX RefNum the same? But when I use this, I get an error message. The same problem I have in my ActiveX palette. There is only an "ActiveX open" available, but no "Automation open".
(3,563 Views)
i send you a screenshot from my palettes (LabView 7.0 PSD, "Advanced" Palette View)
also, try this example, they are using ActiveX-Automation:
\LabVIEW 7.0\examples\comm\axevent.llb
Greetings
Chris
Best regards
chris
(3,563 Views)
