How to implement Java Datagrame socket in LabView
Java DatagramSocket.pngThis is a snippet of Java code to send a UDP command to MiLight WiFi box.
The command is a byte array of hex numbers.
UDP Write.vi in LabVIEW is sending a String. So how can I implement this code in LabVIEW?
(3,174 Views)
The String palette has functions to convert Strings to Byte Arrays, and Byte Arrays to Strings.
Bob Schor
(3,151 Views)
