How to implement PCM in labview?
Hi i know the block diagram of PCM it is nothing but I/p --- sampling --- quantization---- encoding--- PCM o/p but i can not implement it in LABVIEW. Because i do not know how to do sampling please help me
(3,996 Views)
Hi Pradeep
Are you using any hardware to acquire the data and then sampling it. In that case you can use basic DAQmx example VI's. Specify the sampling rate and perform sampling.
Please revert with you specific requirements.
Ashutosh Singh
(3,961 Views)
