How to implement SVR(Support Vactor Regerssion) in Labview or Labview RT?
I want to do SVR in Labview. I studied the Deep Learning Toolkit, but it seems not support the SVR. Is there any demo or toolkit could achieve it?
(2,375 Views)
Recall that LabVIEW is designed as an Engineering Workbench.  If you want a lot of analysis routines using a lot of fancy algorithms that you don't want to learn to program yourself, you should check out Mathematics software, such as Matlab or Mathematica.
Bob Schor
(2,333 Views)
Google "LabVIEW Support Vector Machine" or "LabVIEW Support Vector Regression" gives some promising hits.
It seems IMAQ already can do this, but I'm not sure if it applies to non-image data.
The math itself isn't that scary. If you're into SVR math, it's probably not that hard to make.
(2,323 Views)
