How to implement a Data acquisition in NI myRIO 1900?
Hi James,
Can we directly view the temporary signal from the electrodes when we connect the output of the amplified signal into the Analog Input of myRIO? We're using a waveform chart to view the signal
Yes, you can view your signal directly using this chart…
Right now your samplerate is even less with just 1Hz due to the 1000ms wait in the loop!
Message 11 of 24
(2,547 Views)
So we just need to increase the sample rate? There's nothing wrong with our VI implementation except the sample rate?
Message 12 of 24
(2,545 Views)
Accepted by topic author jamescpe
Hi James,
You can increase the sample rate by reducing the wait time.
BUT: then you are limited by the execution speed of this ReadAI function.
The better option is to employ hardware-timing (if possible) and read more than one sample per Read call!
Again: I guess there are example VIs explaining such stuff for your myRIO…
Message 13 of 24
(2,542 Views)
Thank you! Also, do we need to convert the raw acquired data from myrio into voltage?
Message 14 of 24
(2,528 Views)
Hi James,
with voltage input channels you get voltage values, no need to convert to voltage again…
Message 15 of 24
(2,523 Views)
We can now get the values from the analog input. But we cannot get any negative voltage
Message 16 of 24
(2,528 Views)
Hi James,
which analog input did you use?
There are different types of AI - and all support a different input range!
Read the specs
Message 17 of 24
(2,524 Views)
We used the MSP already and we were able to acquire negative values. Any idea how to convert this waveform into a signal?
Message 18 of 24
(2,520 Views)
Hi James,
Any idea what's the difference between a waveform and a "signal"? (I don't know the difference.)
Which kind of "signal" do you need? Why don't you stick with your waveform?
Message 19 of 24
(2,517 Views)
36526734_1863672963654392_7348945590442524672_n.pngWhen we use a chart it gives us an error. We need this waveform graph because we will use WA detrend VI
Message 20 of 24
(2,509 Views)
