How to implement a general line detection algorithm in a LabVIEW vision FPGA?
Dear all,
We are trying to implement a line detection algorithm in cRIO 9039, but the LabVIEW vision FPGA has limited functions. Can anyone please suggest some examples related to vision FPGA algorithms?
Thanks & regards
Sukumar
(1,617 Views)
Dear all,
In addition to the above question,
I have converted the input image into a binary image using the threshold function; after that, I need to convert the binary image to the 2-D array. If I have 2-D array values, I can do a simple least-square fitting to the image data, but no image to array conversion function is available in vision FPGA. Kindly suggest any approach to converting the image to 2-D array values in the vision FPGA program.
Thanks & regards
Sukumar
(1,559 Views)
@NAGINENI wrote:
Dear all,
A 2D array is usually simply a 1D array of height * width values. So there is really nothing you need to do to treat a 1D data stream as a 2D image other than calculating the stride or byteWidth of the image and looping through the 1D data accordingly.
Rolf Kalbermatter  My Blog
(1,544 Views)
