How to implement a high-order controller in Labview
In LabView, PID controllers have ready-made modules, but for some high-order controllers, such as robust controllers, how can they be implemented in LabView and have a high control bandwidth.
(2,890 Views)
Hi REDJ,
As LabVIEW is a programming language you can program any type of control you like to!
Bandwidth is coupled to loop iteration time: when you want reliable iteration times (nearly constant time with minimal jitter) you should NOT use a standard Windows computer. Depending on your needs you need to use RT targets (like cRIO) or even the FPGA inside those RT targets (like cRIO)…
(2,773 Views)
