How to implement a warning before program is stopped?
Hi.
I have an issue that's probably easy to solve, but which I can't seem to get right.
When the user pushes a Stop-button in the program there should pop up a warning before it is stopped, to confirm that you really want to stop.
What I want is that when the user pushes the stop button - it doesn't change to FALSE before the pup up is confirmed with "yes I want to stop". How can I do this?
The .VI is added, but doesn't solve the problem as it uses a Event Structure based on a value change of the stop-button - but I want the message to come up before the value is changed.
Hope somebody can help me with this 🙂
___________________________________
Is my avatar the dog from the fraggle rock?
(4,272 Views)
I would use the two-button dialog function in Dialog and User Interface. It has a true/false output that you could use to end your program.
(4,268 Views)
If you look at the VI you see that I do use a Two-button dialog button, but I want the (true/false) out of it, to control the start/stop-button when the start/stop-button is pressed. Is twanthere any way to do this?
So I don't want to change the value of the start/stop button when it's pushed down. I want the dialog question to be shown when the start/stop-button is pushed, and if the user wishes to end - THEN the start/stop button changes value.
Hope this clear things up.
(4,261 Views)
your vi is the latest, i can't open it. can you change your vi version to 8.2?
i guess your event is in wrong mode.
(4,254 Views)
Here is what I would do
Tim
GHSP
(4,243 Views)
Here's another way to look at it.
JohnCS
(4,230 Views)
