How to implment multiple checkbox in labview
Hi ,
I have a case in which i need to make a panel with multiple checkboxes and select more then 2 or 3, is it possible to do , can you send an example.
Attached is the example figure i need to implement in labview.
Ankit Gupta
(5,426 Views)
Quick and dirty:
Ingredients:
1. Classic Cluster Set to Size to Fit and made fully transparent
2. System Recessed Frame + Free label with transparent foreground
3. Some number of System Checkboxes
On the BD either Unbundle By Name or Cluster to Array are effective ways to deal with the individual values.
(5,415 Views)
@AnkitG wrote:
Hi ,
Ankit Gupta
That's a very weird way of describing your requirements, because there is no difference between the way you handle "2 or 3" and "15 or 20" or "200 and 4000."  Maybe you meant "more than one?"
Bill
CLD
(Mid-Level minion.)
(5,389 Views)
