How to include uninstaller in installer?
The thing is that application installer in 8.2.1 i can only be used to actually install apllication. If you run it again it will not offer you to modify or reinstall or uninstall your current program. In ver 7+ it was different. Use installer once and you install use it second time and it will act as uninstaller. So the question is how to uninstall custom LV built application without using Control Panel. I can not find a right "checkbox" or anything like that in build configuration so any ideas would be appreciated.
www.xinstruments.com - Custom Software for Industrial Automation
www.hdrconverter.com - Picture processing made easy
(2,735 Views)
I’m afraid there is no built-in way to uninstall everything an installer installs without going into the control panel.
Charlie M. CLD
(2,626 Views)
