How to increase rows in array more than one ?
Hi all ,
I have an application with string array ,
How to increase array index by  x (rows in the array) and not by one as it is in the default ,how to do it ?
10 x
(3,490 Views)
Hide the index if the array and add a plain numeric control in its place where you set the increment to 10. Now feed he output to an "index values" property node of the array.
If you have LabVIEW 8.0, you could make an Xcontrol that does the same. 😄
(3,474 Views)
Hi Doran,
another trick, set your cursor next to the decimal position you want to 'jump' and use the increment control. I *think* you can control the position of the cursor via properties.
Ton
My LabVIEW Ideas
(3,471 Views)
Here;s a simple example of my first suggestion (LabVIEW 8.0).
(3,468 Views)
Thank you altenbach ,
I use the property node and it works greatSmiley Wink
(3,450 Views)
