How to increase the number of rows in the array as needed
 hello LV
I need advice following
1. To the sine signal of 100 data (100 sampling) to sort 250 rows in the array. It changes the sine signal in the plane that time.
2. To set up a new row by external trigger signal.
Thank you
(2,899 Views)
Hi Nusorn,
Your question makes little to no sense. Could you explain further, perhaps send some example code of what you have done so far?
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
(2,886 Views)
In my work
   Sine wave 10 cycle in 1Hz(sampling= 100). i want to frist cycle in the array row 1 and secound cycle in the array row 2. Add rows as cycle increasing and value of cycle is still at that row
(2,836 Views)
Hi nusorn007,
Do you have a VI with what you have tried already?  I think we would be able to assist much better if we saw the code you have tried.  Thanks!
(2,810 Views)
