09-17-2019 06:30 AM
@Mark_Yedinak wrote:We are dealing with quite a few PPLs though multi layers deep. I believe we are up to 170 or so PPLs and about 10 layers deep.
My current set of libraries is more around 55 PPLs and mostly 2 layers deep (parent, child, with each calling other "general library" PPLs).
10-15-2019 10:39 PM
I have finally made some progress with the abstraction definition.
I have created an Instrument class with Init.vi and Close.vi that will be over-ridden by Child classes (e.g. Keysight-PMPS.lvclass and this class will inherit from another parent class called PMPS.lvclass).
But when it comes to integrating them to TestStand, do I have to create additional vi wrapper code to be called in the test sequence or is there a better way/ practice of doing it?
At the moment, I have created wrapper vi to do the initialization (InitPMPS.vi) and closing (ClosePMPS.vi) and these codes will be called in TestStand (Instrument object will be fed to an object reference variable in TestStand and passed along the test steps).
I can't seem to find any examples here that utilizes the LVOOP and TestStand integration.
10-16-2019 07:08 AM
I have wrapper code in the parent class' library. Depending on the instrument type, it could include a lookup (string search to get the object, stored in an Action Engine, useful for things like power supplies where you can have many). Alternatively, from TestStand, you can create an object variable and store your instrument object there.
