How to initialise Tick Count to zero?
Has anyone found a way to initialise Tick Count to zero or even doctor the first reading to make it look like zero. I am measuring the time of repeating burst that occurs every 50seconds. I am displaying the "time between busrts" in a table. Obviously i would like the first input = 0seconds then 50 seconds thereafter. Can anyone help?
(6,059 Views)
(6,055 Views)
(6,053 Views)
You can't initialise the tick count itself to 0, it's set to zero when the computer powers on I believe.
What you need to do is place a tick count OUTSIDE your measuring loop, pass the value to your loop and then subtract this from each and every tick count value afterwards to get a "Time since the program ran".
This is a little imperfect, as the first measurement may be a few seconds after the initial tick count has run, but it's a starting point. Other refinements can be setting a shift register with an initialisation value on the first acquisition, and subtracting THIS every subsequent loop. This requires a bit more code, but gives a true Zero for the first measurement.
Here's a pic of what I mean
Hope this helps
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(6,051 Views)
