How to initialise/initialize array of clusters
I'm trying to initialize an array of clusters of arrays and getting a bit muddled up. Can anyone help?
I've attached the (very simple) VI. I'm sure there's an easy way to do it, but I'm getting nowhere fast.
In case anyone is interested, the array is used in a much bigger application to store XY graph data.
Thanks in advance,
Jon.
(9,952 Views)
You can use a for loop with Auto-indexing.
The attached image has an example.
(9,940 Views)
Accepted by topic author Tournifreak
There's no need to use a for loop to build the array.  You can use "Initialize Array" to do this.
Chris M
(9,933 Views)
Thanks Chris. It didn't strike me. 🙂
(9,921 Views)
Brilliant - thanks so much. It's obvious now you've shown me!
Jon.
(9,917 Views)
