How to initialize the variables in the subvi when the main vi running?
Hi, friends!
Now I am working on a project with labview. I make a main vi  including many subvis.
When the main vi running, I want to reinnitialize the variables in the subvi to zero.
I know that I can realize that  using the local variable when I enter the subvi,
but I want to keep the the values when I left the subvi and saw them when I
click in this subvi again. So, I do not reinitialize the subvi when it runs. But, I
don not know how to reinitialize the indicators in the subvi when I run the main
VI in the first instance. I try to use the global variables, but it seems do not work
well. Would you like to give me some advice? Thanks a lot!
(3,564 Views)
Hi dec,
      If I understand your question, try using the "First Call?" node in your Sub-VI - to initialize values the first time the VI executes every time the top-level VI is Run.
If this doesn't work for you, just post again!
Cheers.
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,560 Views)
Thank you for your helpful reply
The First call.vi works well.Smiley Very Happy
(3,542 Views)
