How to install the 32 bit version and the 64 bit version of lab VIEW 2014 SP1 in the same machine?
Well, if it is so, I apologize for what I said.
Regards!
Once for all!
Message 11 of 19
(1,911 Views)
If you have a 64-bit version of LabVIEW and Application Builder, can you create an executable that's 32bit?
Message 12 of 19
(1,790 Views)
No .  You need LabVIEW 32 bit to create a 32 bit executable.
Message 13 of 19
(1,775 Views)
Yes you have to use the 32 bit Lab VIEW for that, even its better use the 32 bit version, well in my case i use linx with my Raspberry Pi and only the 32 bit version work with that, even that... why you want to run a 64 bit version in a 32, what proyect are you doing? well if you have another question here we are in contact
Message 14 of 19
(1,769 Views)
Thanks for the reply.  That's what I was thinking but wanted to confirm; since there were no options for different OS installs inside the builder.  I'm working on an existing project that was built in 64-bit version.  I needed a 32-bit executable for folks who were running an older 32-bit OS.  Thanks again for the reply.
Message 15 of 19
(1,767 Views)
I have the 64 bit version installed.  I want to install the 32 bit version.  Are the default LabVIEW installers smart enough to separate the 32 bit installation from the 64 bit installation or do I have to do something to ensure the second installation doesn't trash the first installation?  Can I just blissfully click the default options as I go through the installation?
Message 16 of 19
(682 Views)
Yes, those are intelligent; you can have both 64-bit and 32-bit side-by-side, and even multiple LabVIEW versions co-exist without any issue.
Santhosh
Soliton Technologies
Message 17 of 19
(673 Views)
There is one caveat to mention with multiple LabVIEW versions side by side. That works for LabVIEW itself for as long as your disk space allows it, but if you use certain Toolkits or drivers such as DAQmx you are more limited. Those drivers usually only support the version of LabVIEW that was current when it was released and 3 earlier versions. And they will actively remove earlier installations of the same driver from any LabVIEW installation, even much older ones!
With the new version independent driver installation of LabVIEW drivers this has changed but those don't work with LabVIEW before 2022. Older LabVIEW versions do not know about version independent drivers!
Rolf Kalbermatter  My Blog
Message 18 of 19
(663 Views)
Thanks.  You saved me some headache.  I heavily use the tool kits.  I think I'm better off using a second PC than gambling with trying two installs on the same machine.
Message 19 of 19
(652 Views)
