How to install the NI-DAQmx driver on a real time target PC?
Hi, I’m painful about how I can install a PCI-6363 DAQmx on my real time desktop PC target. The PCI-6363 is directly connected to the real time PC. And I’m using LabVIEW 2011 and MAX 5.0.
The DAQmx device driver can be seen in software lIst in the host PC, but it can not be found in the install wizard. Is there something wrong with my host PC? or is that wrong to connect PCI-6363 with real time desktop PC?
I would be grateful for any advice that I could get here.
(4,021 Views)
Accepted by topic author Zhleo
Hi Zhleo,
If you are about to use the PCI-6363 with the Real-Time Desktop you are right you need to have it installed, and then you need to deploy DAQmx driver software to the real-time target.
To do that you access your real-time desktop under Remote Systems in MAX and start the Real-Time Software Wizard. There you should see DAQmx listed.
In case you do not have DAQmx listed there, see this KB: Deploying DAQmx to a Real-Time Controller or PC?
Eirikur Runarsson
(3,987 Views)
Hi, Eirikur,
Thank you very much for your suggestions, I update the drivers for NI-DAQmx hardware on host PC and ensure the Real-Time support for LabVIEW has been installed, then I can install the drivers from host PC to Target PC now.
Br,
Zhleo
(3,978 Views)
