How to integrate AI signal through FPGA
I build fpga VI in while loop to acquire AI signal and I need to intgrate this signal twice to obtain the velocity and displacement. I found integrator in Simulation and design but I can not put the integrator in FPGA while loop
(3,488 Views)
Is it a regular while loop or timed loop?  Can the integrated be used out side of the loop?  For example, acquire your analog signal in one loop and pass it to a slower loop for integration.
Kudos and Accepted as Solution are welcome!
(3,481 Views)
Thanks 4 reply
It is normal while loop.
The problem is that the integrator exist is simulation and design module
Is it possible to put another loop containg the integrator
(3,477 Views)
From a VI under an FPGA target, look at FPGA Math & Analysis >> Control >> Discrete Linear Systems >> Discrete Normalized Integrator
Jim
(3,460 Views)
Thanks a lot
(3,444 Views)
