How to integrate an Array with the other Array???
Hi guys,
I have such a problem that need your help!!
I have two columns, the first column is Time (x): 1, 1.2, 1.5, 1.7, 1.8... which is uneven array.
The second column is Y :  3, 5, 7, 8....
X and Y have the same length, but the x is uneven. Now I want to do the integration of Y on x. When I use the uneven numeric integration, I found that the integration result is only one value instead of an array. But what I need is the third column which shows the integration results C. So I could plot C against x, and know how the integration goes.
Does anyone has such an experience, thanks a lot!Smiley Happy
Basically, what I need is just like the integration what the Origin Pro does.
Tao
Message 1 of 8
(4,709 Views)
What do you mean by "X is uneven"?
What do you mean by column C to see how the integration goes?  Do you mean that you want to see the integration from X0 to the current X step by step throughout the whole array?
Message 2 of 8
(4,685 Views)
Is this what you are looking for?
Message 3 of 8
(4,667 Views)
Accepted by topic author tzou
Or at little bit cleaner code...
Message 4 of 8
(4,665 Views)
Yes, exactly.
Message 5 of 8
(4,645 Views)
Hey,
I input the same T and current values as you gave to Origin Pro, and do the integration, the values are different from this VI. I am confusedSmiley Happy
Message 6 of 8
(4,632 Views)
Chris' VI just does a continuous summation of the Y values.  It failed to do the multiplication by the dX.
You still haven't said what you meant by uneven X.  Did you mean that the delta X's are unequal?
Message 7 of 8
(4,619 Views)
Hey, Thanks for your reply.
I have figured this out based on what Origin does.
Thanks again.
Message 8 of 8
(4,605 Views)
