How to interact Motor Controller with Load cell via LabVIEW
Dear all,
I am kindly asking you for help to programming my Test setup which is indicated below:
I have a loadcell, motor and a motor controller, i have all the motor controller labview drivers!
The question is: i dont know how to use these labview drivers and how to interact the motor controller with the loadcell.
Please have a look at the summary of the working principle for this setup below:
While the linear stage  is running on a single axis via the motor controller ,  the linear stage touches the loadcell and  it is starting to make compression on load cell and after a specific, predefined Force, (for example 10 Newton) on the loadcell, i want to stop the motor so it does not go further, and then start to moving the linear stage at the negative direction now it will make a tensile strength on the load cell then again i will want to stop the motor controller when the loadcell reaches the predefined force (for example 10 Newton)
I read all the data sheets but it is not indicated that how to use these labview drivers, For example: How to turn the load cell’s output to an input to the motor controller? should i use “acceleration”and “set velocity” drivers next to each other? How to connect them? Doyou know any similar or exact codes? Which product should i use? (SignalExpress? Regular Labview? Control&Simulation? etc..)
Please have a look at my brand new equipments below:
Motor Controller= Newport SMC100CC Single-axis DC motor controller/driver
Motor Linear Stage= Newport MFA-CC Miniature Linear Stage DC motor
DAQ= NI USB-6343, X Series Data Acquisition
Loadcell = Transducer Techniques, GSO-100 (Tension&Compression)
Loadcell Signal Conditioner = Transducer Techniques STAND ALONE / BENCH TOP, 0 to ±10VDC OUTPUT
Thank you for reading,
Have a nice day,
Best Regards,
Kindly wisher.
(3,898 Views)
Hi there.
When you say you have the LabVIEW motor controller drivers, do you mean you have downloaded NI-Motion? (https://www.ni.com/en/support/downloads/drivers/download.ni-motion.html)
If so, how are you hooking the Newport motor controller to your computer?
The NI-Motion VIs and drivers are designed specifically to work with NI's motion controllers. If you're trying to control the motor with our USB-6343, you might have to design very low-level operations built yourself from the ground up.
Ravi A.
National Instruments | Applications Engineer
(3,878 Views)
Dear ravi.antavi
Regarding the motor controller's labview drivers, I mean these documents: ftp://download.newport.com/MotionControl/Current/MotionControllers/SMC100/Software/
Do anybody have any idea how to coordinate the motor controller while taking care of the loadcell resuls? Is that so hard? !!
Best regards.
Kindly-Wisher.
(3,859 Views)
You could look into triggering or event structures. This way, when you reach a certain number, you can have another piece of code in LabVIEW execute.
Ravi A.
(3,831 Views)
