How to interface 4 voltage inputs using LabView
I need to interface an EOG 4 channel output to labview using any cheap(cost wise) hardware. I would prefer using a microcontroller.
(2,941 Views)
OK, just a couple of questions first:
What is an EOG?
What have you tried so far on this project?
What hardware do you have or have you considered?
What microcontroller do you have or have you considered?
What OS are you going to run or have you considered?
Are any of the above compatible with LabVIEW (notice the spelling here)?
What version of LabVIEW are you planning to use?
Do you know anything about instrument interfacing?
Do you know anything about LabVIEW?
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(2,931 Views)
EOG: ELECTRO OCCULO GRAM
i am trying to control mouse pointer using eye movements.
I want to use atmega or audrino microcontroller.
I have basic knowledge of DAQ
I am using LabVIEW 10.
(2,905 Views)
