How to interface Atmega16 avr controller with labview?
I want to interface my AtMega16 microcontroller with labview to display the analog values read by the controller. Can anybody tell me which driver or what configuration should i use to interface it with Labview 2012
(5,634 Views)
hello for this work:
1.  Make a microcontroller embedded in the program that I made reading and writing serial port for example using a USB-Serial adapter
2. VISA drivers to use the serial port reading Deed
You can see a link on the forum that also addresses this issue http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/microcontroller-interfacing-with-serial-port-...
(5,397 Views)
