How to interface Vacuum Transducer
I am using IFM make Vaccum Transduer.
 range= -1 to 10 bar
 Output voltage = 0 to 10 V.
I interfaced my transuder and collecting the data in voltage value.
I want to change this voltage value to Bar value.
But i am not able to find the correct Scalling value.
So kindly send me the Scalling value for above mentioned transducer.
Thiyagarajan.S
Thiyagarajan.S
WABCO Vehicle Control System
(3,447 Views)
Accepted by topic author Thiyagu
The scaling factor value you are searcin (I'm supposing you transducer is a linear transducer) is 0.90909090909090909090909090909091, it is taken dividing 10 (max scale voltage range) by 11 (the bar got adding the modulus of -1 + 10)
I hope it was helpfull.
Regards.
Ricky
Italian Developer engineer
www.www.selt-sistemi.com
(3,443 Views)
Hello Ricky,
     Thanks for youe reply.
     It is working.
Thiyagarajan.S
(3,427 Views)
Nice to hear that... Please, Click on the kudos star!!
Good work!
Ricky
(3,419 Views)
