How to interface keyboard or joystick controls?
There are 2 parts here, and in both we can't really help you without more info from you.
You need to know the protocol because unless you know what kind of command the RF unit expects, you can't know how to convert your data to fit that command. You also need to know it to actually construct the command itself.
You can convert numbers to the string you will need to send using the VIs in the string palette, but you will need to know what the unit expects.
If you understood how serial communication works in LV (from the examples), you should be fine once you have the protocol.
___________________
Try to take over the world!
Message 11 of 13
(862 Views)
Hello Grad:
I would like to know where and what program you used for video streaming for your project -- this is some component for my remote confocal microscope project. I would appreciate it if that you could send to me on a private email.
Berns B.
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
Message 12 of 13
(848 Views)
Hi, Sorry if I didnt email it to you cause I couldn't locate your email. Anyway heres the link to the site that provided me the software. Hope its of use to you!
http://www.hytekautomation.com/Products/IVision.html
Message 13 of 13
(838 Views)
