How to interface xbee with labview without the use of arduino in any way?
I wanted to connect the xbee receiver to labview and use the data for graph and other purposes. The transmitter side will have a microcontroller other than arduino. As there will be no readymade VIs to design it(as in the case of LIFA). How do I go about interfacing xbee using visa resource? (I am completely new to labview)
(2,766 Views)
if you interface microcontroller with xbee module, on serial port send/receive command through labview serial visa resource.
(2,721 Views)
