How to invoke different constants?
Hi. I want to send different constants(t,b or c) to visa write instead of write control. The constants should be sent when i press a button in front panel.
(4,233 Views)
Hi madara,
simple answer: use case structure(s)…
Better answer: use an enum or a ring control with a case structure…
(4,219 Views)
Even better answer: Use a combo box as a control that can then be written directly into the VISA Write.  No case structure necessary.
(4,199 Views)
Hi crossrulz,
sometimes you might not want to send a command at all, so I still suggest to use a case structure 🙂
(4,191 Views)
GerdW wrote:  sometimes you might not want to send a command at all, so I still suggest to use a case structure 🙂
That is true.  But not in this case.  From another thread (http://forums.ni.com/t5/LabVIEW/When-highlight-execution-is-quot-ON-quot-i-get-the-output-but/m-p/32...) I know the instrument uses a command-response protocol.
(4,180 Views)
