How to konvert a string in following form "-1.3184E-07?33" to a double or float or similar?
You can use the "Scan from String" function (in the string sub-palette).
Message Edité par chilly charly le 09-13-2005 04:37 AM
Chilly Charly    (aka CC)
(2,588 Views)
Simplest is "Fract/Exp String To Number". It does exactly what you need. 🙂
(I assume you don't need the ?33 part of your original string.)
Message Edited by altenbach on 09-13-2005 12:00 AM
(2,577 Views)
