How to label Y axis values on a graph?
HI,
I have a histogram graph and I need to make labels on the Y axis that reflect how many lines hit that line. So that if I have 10 1's then on the amplitude line I would have a digital indicator showing 10 next to the 1? And same thing say 15 for the 2's if thats the number of lines that hit the 2 on the Y axis. Basically what do I use, a property of the graph or do I manually insert digital indicators on the front panel?
(2,596 Views)
The General Histogram VI allows for min and max tolerances and will output the number of hits outside of that range. You could use that VI in a while loop and wire the out-of-range values to shift registers, along with an "Add" VI, to create a running sum. You'd need to do this for your X & Y axis.
Also, for an example, the Running Histogram Example shows a use of the General Historgram vi output, buts converts the out-of-range values to % versus a running sum.
However, as you also thought, using simple indicators along with the "In Range and Coerce" VI (Functions > Comparison) wired with the graph data input (X and Y separately) is another method that would fit just as well, and may be easier to implement.
I believe either way will work fine. Good luck with it, Do
ug
(2,596 Views)
