How to limit the user access in the alarm and event display?
Hello
I am using DSC module in LabVIEW 2012 and find alarm and event display AcitiveX so interesting and useful. The only problem is that I do not want the user to have the ability to change the process or filter option. Is there a way to remove these options (i.e. “Filter Options…” and “Select Processes”) from right click menu? It should be mention that I would like the user to have the ability to acknowledge the alarms and events.
Thanks in advance
(3,270 Views)
If you create an EVENT handler for the event "Menu Activation? - user"  (note the question mark), then you have a chance to intercept the event AFTER the user has clicked on the control in question, and BEFORE the menu pops up.
In that handler, you can remove items (if you know their tags), and offer your own items if needed.
Steve Bird
Culverson.com
LinkedIn
(3,206 Views)
Thanks a lot.
Is there an example for this?
I do not know how to remove items in right click menu and offer my own items.
(3,182 Views)
Yes:
I don't know anything about the "DSC module" but if YOU handle the control, then YOU can intercept the event and customize it.
Steve Bird
Culverson.com
LinkedIn
(3,165 Views)
