How to list devices available ?
Hello all,
I am new on the NI forum and I recently followed Labview training (Basic 1 & 2).
I would like to know how to get the list of available devices and the type of them.
Ideally I would like to have an array of that form :
Device Name          Device Type
Dev1                       NI PCI 4472
Dev2                       NI PCI 6731
Is there a way to do that with Labview ?
Thank you for your help.
Olivier Schevin
(3,361 Views)
Look at the following simple Vi.  It took less than a minute to make but uses DaqMx to return an array of clusters with the info you should need.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,345 Views)
The example uses Labview 7.0 and DaqMx version 7.3
Paul
Paul Falkenstein
(3,344 Views)
In Classic NI-DAQ, you simply use NI MEASUREMENTS | DATA ACQ | CAL & CONFIGURATION | GET DAQ DEVICE INFORMATION.vi.
In a loop, feed it a 1-6, and get the DEVICE NAME and DEVICE TYPE CODE and whatever else you want out of it.
For DAQ-MX, use a NI MEASUREMENTS | DAQmx DATA ACQ | DAQmx ADVANCED | DAQmx SYSTEM SETUP | DAQmx DEVICE PROPERTY NODE
In a loop, feed it a "Dev1" - "Dev6" string as the ACTIVE DEVICE, then read out the PRODUCT TYPE, SERIAL NUM and IS SIMULATED.
Steve Bird
Culverson.com
LinkedIn
(3,343 Views)
I use the node:
Device Names Property
Short Name: DevNames
Property of DAQmx System
Indicates an array that contains the names of all devices installed in the system.
This returns all device names without making an assumption about naming conventions such as Dev1 to Dev6. daqMx allows for naming the device with meaningful names through MAX.  I would encourage using daqMx, I found it a large learning curve over traditional DAQ but was well worth the time.  I would also assume with DaqMx there will be a phase out of coding using traditional drivers over the next several years (I could be wrong about this) .
Paul
Paul Falkenstein
(3,334 Views)
Thanks for your help everybody !
Olivier
(3,313 Views)
