How to load the bitmap file programmatically in to the front panel?
I wanted to load Bitmap file programmatically in to the front panel. Can any one guide me ?
(3,949 Views)
Hi Selva
Here you can find a little VI which loads a Bitmap file into a picture control:
http://ae.natinst.com/devzone/explprog.nsf/41ee12ddba6c766a8625684700691463/582e53e2c82a4dbe86256a8d006a4a82?OpenDocument
Luca
(3,949 Views)
The link page is invalid. Get me the corrected link.
(3,949 Views)
Ok, here is the VI.
Luca
(3,949 Views)
Thanks and it helped me a lot.
Is it possible to open a JPEG file ? If you have any sample VI. Kindly post it.
(3,949 Views)
Just replace Read BMP by Read JPG vi.
VI's founds in Graphics&Sound\Graphic Formats pallete.
(3,949 Views)
Very simple.
1) Put picture indicator on the FP.
2) Use "Read BMP" vi.
3) Use draw flattened pixmap vi.
4) Connect all outputs of "Read BMP" to all inputs "Draw flattened pixmap".
5) Connect output new picture of "Draw ..." to picture indicator.
Attached example of this procedure.
(3,949 Views)
