How to localise General Error Handler?
is there a human way to localise the GEH?
I mean the final window that appear has the button and some string with english fixed text. I went inside the VI.
I don't understand the concept of this VI: NI made possibile to put custom strings (via the [user defined codes] and [descriptions]), BUT the VI is english fixed...
thanks
(2,790 Views)
Hey Slyfer,
Unfortunately I don't think what you're trying to do is possible. I have tried using property nodes to change the language in the VI but the node will only allow you to read the value, not change it. Sorry I can't be of more help.
Regards
Chris
National Instruments - Tech Support
(2,767 Views)
