How to lock the random values?
Hi all,
 I want my pressure input in range of 250 to 280 values...i.e. mV input is coming to LV via cFP..I converted that to 280 by mathematic manipulations.
now I want that if values goes above 280, it should give 280 as a constant value and if values moves down to 250 according to mV, it should give constant output 250 despite of incoming values..
Can anybody guide me?
Vaibhav Gandhi
B.E. Instrumentation & Control,
INDIA
(5,178 Views)
For example, use 'In range or Coerce' from Comparison palette.
Message Edité par J.DECHET le 01-12-2010 12:01 PM
(5,176 Views)
"In range or coerce" returns the boolean value,..
i need upper/ lower limit as an indication..
sorry i m not getting
Vaibhav Gandhi
INDIA
(5,172 Views)
Accepted by topic author Vaibhav G
a simple complement to previous but to adapt to your needs:
(5,164 Views)
Hi Vaibhav,
you should read messages more carefully!The output in the first answer is clearly not a boolean (it's a double)...
And by reading the context help for "In range and coerce" you would see that it provides 2 output values...
(5,147 Views)
Hi sorry, but i ve got such at first try..
anyways thanks for advice...
Vaibhav Gandhi
INDIA
(5,141 Views)
You can mark J.DECHET's post as soution.
Shreyas Hebbare
Shreyas Technologies
India
(5,116 Views)
