How to (logical) compare two arrays
i have two boolean arrays.
A[0,1,1,1,0,1,0,0,1,0,0,0,0]
B[0,1,1,1,0,1,0,0,1,0,1,1,0]
They have same size. The only difference are the last two 1,1 in array B.
What do i have to do to get an array that contains only the differences?
C[0,0,0,0,0,0,0,0,0,0,1,1,0]
Thx
(3,856 Views)
hi onlyone,
have you tried the Exclusive Or Primitive?
http://zone.ni.com/reference/en-XX/help/371361H-01/glang/exclusive_or/
(3,845 Views)
Jim
(3,840 Views)
... And if you want less obscure code, simply use a "not equal" from the comparison palette, same result. 🙂
"Not equal" is much easier to understand for a new programmer than the geeky " xor". It is also more universal and works for arrays of any datatype. For example xor will do bitwise for integers and won't work for DBL, != will always give you a boolean array showing which elements differ.
(3,811 Views)
As long as you compare elements (Default) there is a Right Click Menu option to compare aggrigates that you do not want to use in this case.
(3,796 Views)
Yes, I was talking exclusively about "compare elements".
XOR does not have an equivalent option to "compare aggregates" anyway, we would need to add an "OR array elements" afterwards.
(3,785 Views)
The concern was:  "Sometimes newer users just copy and paste primitives from existing code untill they learn to navigate the palettes."    Or I would not have mentioned it.  Oh! the trouble they can get into that waySmiley Surprised
(3,776 Views)
