How to loop for txt file ?
Hi all,
I would like to send the string data into txt file. I had successfully send the last string information into txt file after I stopped the operation.
Since I need to acquire the string data in live time, may I know how to loop for the txt file ?
I tried to put a while loop for txt file but it doesn't work as what I expected.
Hope to hear from you guys !
Message 1 of 8
(1,987 Views)
You've got a serious data flow problem in that tiny picture of your code.  You need to look over the LabVIEW tutorials again.
  • You have a while loop that executes forever.  The outer while loop will never get a chance to run a second iteration.
  • That while loop runs as fast as it again doing the same thing over and over.
  • The while loop acts on the same data on every iteration.  Whatever is in the pink tunnel.
Start by getting rid of that inner while loop.
It is impossible to help more since you didn't attach your VI so we can see what is really going on in the rest of your VI.
Message 2 of 8
(1,966 Views)
Here's my VI. Hope it helps.
Message 3 of 8
(1,957 Views)
As RavensFan said, you need serious dataflow change, you have wires going all over the place. Generally it's frowned upon if the wire goes backwards (unless you are using feedback node or similar).
You should open file only once, at the start of your program, and then write to it and close when program stops. What you are doing here is opening the file on every loop, write a glob of data into it and then close it.
The way you concatenate strings together you just get a single string out, no spaces or line breaks or anything, that file will be very hard to read.
EDIT: just noticed that you also use empty error constants before each IF, that does absolutely nothing and should be removed.
Message 4 of 8
(1,926 Views)
A cleaned up version of your code with the file handling fixed.
Message 5 of 8
(1,892 Views)
Message 6 of 8
(1,888 Views)
Ahha, thanks !
I didn't know that there's a method to clean up the wiring.
Message 7 of 8
(1,883 Views)
Thanks alot, truely appreciated.
Message 8 of 8
(1,882 Views)
