How to lunch Labview Database Connectivity Toolkit
I have installed Labview database connectivity toolkit in my computer, but I cannot find any way to lunch it (there is no icon or menu item for this program being accessed).
I also tried to reinstall it, but with no success.
Has somebody any idea about what is going on...
Thanks in advance,
msandro.
(3,183 Views)
A toolkit is more like an assembly of VIs. It's not an application that you launch. You should be able to find the Database VIs in the block diagram palette.
You also can find example VIs using the NI Example Finder. Select Help»Find Examples in LabVIEW to launch the NI Example Finder.
Use the Browse or Search page of the NI Example Finder to find an example VI. In the Browse page, the Database Connectivity Toolkit examples are located in the Toolkits and Modules»Database Connectivity folder.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,175 Views)
