How to make Multi Option Radio Button Boolean control? I mean of the many options available only one can be opted. For example as appeared in attached fig .one can select either "Yes" or "No".
Are you looking for the simple radio button?  It's found in the system controls->boolean palette.
EDIT:  Yeah, I guess there's a "Modern" radio button as well.
Message 3 of 12
(14,092 Views)
Ohhh.., that was simple, but unfortunately I am working in older version LV7.0 which does not have this option Smiley Sad
Message 4 of 12
(14,076 Views)
It's in the classic palette also, so I imagine it has to be there in LV7.0.
Message 6 of 12
(14,070 Views)
Don't know if you tried, but did you use the seacrh feature in the palette menu to look for "radio button?"
Bill
CLD
(Mid-Level minion.)
Message 8 of 12
(14,038 Views)
Version 7.1 introduced the radio button so the op cannot find what is not there.
alt_234,
Have you done a search. There is an older example here.
Message 9 of 12
(14,032 Views)
Accepted by topic author alt_234
This is a small extraction of a library I created looooong ago, using the control editor in some non-trivial ways to create codeless radio buttons. I think it is in LabVIEW 4.0 or 5.0 format, but will open fine in LabVIEW 7.0. Basically they are customized slider controls, and their edit behaviour is a little less convinient than the newer native controls in 7.1 and newer but they do work.
Rolf Kalbermatter  My Blog
Message 10 of 12
(14,013 Views)
