How to make VI front panel full screen?
I have a VI whose front panel I want to make full screen.  I have tried showing the front panel when the VI is loaded and having it maximized.  The result is closed to what I want...the front panel occupies the entire screen except for the Windows taskbar.  How do I get the front panel to also cover the task bar?  I want to do this to prevent people using my program from being tempted to play with other things on the machine while my program is running.
Does anyone know how to make the VI front panel truly full screen?
I am using LabVIEW 8.5 on Windows XP.
Thanks in advance.
Message 1 of 8
(11,726 Views)
Have a look here
Ton
My LabVIEW Ideas
Message 2 of 8
(11,722 Views)
Hi nickle
In addition to overlay the taskbar with your Window you can hide the taskbar with the function from user32.dll.
Mike
Message 3 of 8
(11,717 Views)
Hi Mike,
            I went through your post but was not able to find USER32 function in labview.Can you please tell me where can i get the USER32 function in labview as i wanted to hide my windows taskbar.
Nitin
Message 4 of 8
(8,263 Views)
VI properties
Set window run-time position: maximize
Set Window appearence: custom to Dont has title bar, dont have menu bar.
Or the taskbar is a problem?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 8
(8,251 Views)
@Nitin.sg wrote:
Hi Mike,
Nitin
That's a Call library-node. You invoke windows DLL's directly.
What are you trying to achieve?
/Y
Qestit Systems
Message 6 of 8
(8,250 Views)
Hi Yamaeda,
                   I my project when i minimize my Front Panel i get a access icon in the taskbar.How can i remove the access icon in the taskbar??
Nitin
Message 7 of 8
(8,222 Views)
Hi Nitin,
If you want to prevent the user from minimizing your Front Panel, you can modify the Window Appearance properties in the VI Properties dialog to prevent the user from minimizing the window. If you want to hide the Windows taskbar, you will need to do that programmatically by using the Call Library Function Node. An example on how to programmatically hide and show the Windows taskbar is available at http://zone.ni.com/devzone/cda/epd/p/id/1450.
Matthew B.
Offering Manager
NI
Message 8 of 8
(8,166 Views)
