How to make a circular CROP on the image out in the labview?
I put an  image with the 'image out'. I want to get rid of that black area and only have the circular area with the color image.
(1,073 Views)
What tools do you have available? Can you use NIVision?
The cropping itself will be easy once you find your area.
The output will be square though. Making the remaining black transparent shouldn't be too hard.
However even the easy parts will be completely different if you have NI Vision.
(1,024 Views)
