How to make a .exe without errors about the costum scaling
Note: two different values of any type (as long as bot their types are the same)
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 12
(479 Views)
Hello Thierry,
i want to use Analog Input AI1
Analog input AI0 is allready in use for the input of Rpm ....
i will try to make a ''select'' node ....
the loop period ... , do you mean the loop period of the select node it self?? because it does not have to execute quick... its just for having the choice of   OR the Analog input   OR the Digital Dial on the screen...
I'm currently not at home but i will try it out when i'm back!
Thanks anyway for helping!
Kind Regards,
Kris
Message 12 of 12
(474 Views)
