How to make a "Ding" sound and "block" other VIs when a subVI is open?
Hello everyone,
I am working in a user interface with a main VI and some subVIs and I would like to add the "property" that windows uses sometimes to force the user to select something that is on a given window (in this case would be in a subVI).
In windows, when there is a small window that emerges, the user is forced to select one of the alternatives. In such cases, when the user clicks outside of the window, there is a "ding" sound, the small window blinks, and the mouse can not select anything from other windows (I hope I could explain my self).
That is what I would like to implement in labview (if it is possible).
Many thanks,
Daniel
(3,621 Views)
Accepted by topic author Daniel_CB
Just set the VI to be Modal.  Go into the VI properties, then the Window Appearance tab.  You can just select the Dialog option for a quick fix.
(3,613 Views)
Thanks!!
That is exactly what I needed!
(3,560 Views)
