How to make a single boolean on/off continuously on time bases?
Hello all,
I am new user to Labview, and I just wonder how can I control a LED which swich on-off automaticaly for a while, with time of "on=2 sec", and "off=1sec"
I tried  different things but I am not able to control the time which the LED is on and off.
I will apreciate if you could please help me.
Thank you.
Message 11 of 15
(1,015 Views)
Then start a new thread instead of appending to a discussion that is over 4 years old. Show us what you tried and we will explain what's wrong and how to do it better.
  • How long is "a while"?
  • What should happen before and after "A while"?
  • "I tried different things" is very vague. Can you be more specific?
  • What else does the program do?
In the simplest case you could have a while loop with a wait. Toggle the LED and wait time depending if the iteration terminal is even or odd. Code would probably fit on a postage stamp. 😮
Seems to be related to your other discussion. Why not keep it all in one place?
Message 12 of 15
(1,009 Views)
Message 13 of 15
(999 Views)
Dear Altenbach,
Sorry for my mistakes.
Message 14 of 15
(963 Views)
Dear Altenbach,
I used the vi that you provided in first page of this discussion (alternating LED) and it is working well with LEDs but I have problem to connect this on-off switching to DAQ Assistant. I wired form boolean and I used boolean to integer and then to DAQ, but not working.
one more thing is that, for the DAQ and the task of switching on-off should I use analog or digital output?
Message 15 of 15
(953 Views)
