How to make a weekly event scheduler
I need a weekly event scheduling vi and I am not sure if it is already done or what would be best to use to make it.
I would like to be able to set each day seperately on half hour incriments. I have about 4 events that need to be considered and with half hours this creates a massive ugly matrix if I use enumerators.
I was thinking it would be kewl to use something simular to the Draw graph tools and format it into a time and such but had a lot of difficulties in making multiple graphs (Sun-Sat thus 7 are needed but no x cord is needed). If this were done then I would set events by using different colors or something.
I hope someone can point me in the right direction. Thank you.
-Collin
Message 1 of 19
(7,328 Views)
Message 2 of 19
(7,315 Views)
No that does not really help. I am more particular about the GUI of the scheduler. I know it should be able to be done with out much trouble in LabVIEW on the timming sence but organizing a easy to use GUI is a bit difficult.
The one you showed is more for just one event and setting it on a day.
I need something more for a weekly planning of a complex schedule which could have more than 4 events taking place every half hour (so 48 periods per day).
Thank you for the suggestion though.
Anything else?
Message 3 of 19
(7,292 Views)
Have you got an example of any existing software package that will do this??
Message 4 of 19
(7,283 Views)
I have not used it by my boss said "Security Spy" works like that. It is a program that turns on and off cameras with the set intervals. It might be a strictly Mac based program because that is waht we have it on.
Message 5 of 19
(7,277 Views)
Here's a quick example (7.0) for how something like this can be done - the colors represent the tasks, you select a color and then click and drag to select which cells will receive that color. There are 48 columns and 7 rows.
Is this enough or do you need to set tasks to run concurrently?
___________________
Try to take over the world!
Message 6 of 19
(7,275 Views)
Sounds to me like you want a drum sequencer in labview. Maybe with 15 minute increments for 24/7/365. Maybe a timestamp control or just boolean checkboxes.
Message 7 of 19
(7,263 Views)
That will work great!
Thank youSmiley Very Happy
Message 8 of 19
(7,234 Views)
tst-
Where are the colors being set? Since green and red are often color blind to some people I want to adjust one of them but can't seem to find where you set them....
Message 9 of 19
(7,256 Views)
I used a picture ring. I simply took one of the LV decorations, made several copies, painted each a different color, Ctrl+Ced each copy and then imported it into the ring.
___________________
Message 10 of 19
(7,248 Views)
