How to make calculation based on hex display?
I am trying to convert a float number to hex, then get the sum of each byte. Please see attached pic, e.g. 30.5 convert to 403E 8000 0000 0000 using hex dispaly. I want to get the sum of each byte, 40+3E+80+00+00+00+00+00, how could I do it in the labview.
Any help will be greatly appreciated!
Stephen
(3,676 Views)
Accepted by topic author stephenzhou74
I didn't try, but I think you can use "String to Byte Array" and then add the array elements.
Hope this helps,
Daniel
(3,672 Views)
Thanks a lot! It works!
(3,664 Views)
You can eliminate one more step by typecasting the dbl directly to an u8 array.
Message Edited by altenbach on 05-08-2010 04:58 AM
(3,645 Views)
One thing to take care:
The sum of the U8 array might easily be > 255, so the U8 containing the sum might overflow. To prevent this you might have to transform the array to U16.
(3,613 Views)
