How to make common control?
Hi Dusk,
why are you creating several subVIs which contain the very same content? (Atleast it seems so from a quick glance at them.)
They are calling some DLL functions: either the DLL supports multithreading, then you should set your VI reentrant - or they don't support multithreading, then you should call them one after the other…
Anyway the problem is in your main VI: Learn to use autoindexing and learn, how to handle arrays!
Both are basic LabVIEW concepts and you should know about them, before handling DLL calls…
Message 11 of 11
(732 Views)
