How to make continuos measurement using DMM?
Hi, I am trying to use the PXI-4071 with LabVIEW 2015 to make a continuos measurement of the voltage.
I want the x-axis to be time and the y-axis to be bolt. But how can you solve the example file when the x-axis comes out as a sample?
I have tried the DMM Example but no one of the example does what i want. I have tried to modified one of this program, but I can't even set the x-axis to be time and continuos measuremnet function.
Can anyone help me? Thanks
(2,156 Views)
The first issue... "Continuous" would imply some kind of loop. I don't see a loop in your picture of the code.
Second issue, you might want to check out the free LabVIEW training.
Former Certified LabVIEW Developer (CLD)
(2,145 Views)
