How to make current value to default to all controls at once
Choosing "Data Operation" -> "Make Current Value Default" to multiple controls requires a lot of clicking. Is it possible to do this with one click?
(6,536 Views)
Accepted by topic author esanum
Yes.  If you select no controls, it says "Make current values default", and it does all the controls at once.  If you have a control selected, then it does only the selected controls.
Reinitialize current values to default works the same way.  Select nothing, it does all the controls at once.
Bob Schor
(6,532 Views)
Thanks for the fast response.
That was easy 🙂
(6,525 Views)
Dumb follow-up question:  How do you get to the Data Operations-Make Current Value Default if you don't select a control? I've only ever done this by right clicking on a control, but I can't find out how to access the Data Operations features without clicking on a control. Thanks!
(6,188 Views)
The response that Bob had given is based on going to the Edit menu.
(6,182 Views)
Got it, thanks!
(6,178 Views)
